INICIO › FOROS › NOVEDADES › Fotos espía y futuros modelos › 2011 Audi A4 B8 Facelift
Etiquetado: 2010 Audi RS4 B8, 2011 Audi A4 B8 Facelift, 2011 Audi A4 FL, Audi, Audi A4 B8, Audi A4 B8 Facelift
- Este debate tiene 149 respuestas, 43 mensajes y ha sido actualizado por última vez el hace 13 años, 3 meses por
marna.
[img width=600 height=263]http://i26.tinypic.com/2djxfmg.jpg [i]The last new Audi RS4 to roll out of a showroom was back in early 2008. At the end of that year the German automaker has already released a new generation A4 with the theme of downsizing for efficiency. With the new body also comes a new RS4. Audi prefers to wait until they are closer to the end of their product’s life cycle before developing and all out factory tuned hot rod and so the word has just broken that the next four-ringed sports car to wear the RS4 badge will go n sale in the spring of 2010.It is possible that the German automaker is aiming for a Geneva Motor Show launch, looking forward to embarrassing competitors offerings like the Mercedes Benz C63 AMG, the BMW M3 and the Lexus IS-F. The current trend is a high horsepower combination of speed and luxury, however none of these other high performance machines can match the handling performance of Audi’s Quattro all wheel drive system.
The 2010 Audi RS4 will be powered by a V8 engine that will deliver an impressive 450 HP, a gain of 30 HP compared to the old 4.2 Liter FSI equipped RS4. The future super sedan will also feature larger air intakes in the front bumper, inspired by the Audi TT-RS and the upcoming RS5. Like all of the rennsport models, the RS4 will wear a more aggressively styled aero kit.
[/i] Chop >
[url url=http://www.autogespot.com/item/4716/nieuwe-audi-rs4-moet-concurrentie-verpulveren/][u]Autogespot[/u] [/url]
Información >[url url=http://www.topspeed.com/cars/car-news/audi-will-bring-the-new-generation-rs4-in-2010-ar77585.html][u]TopSpeed[/u] [/url] [quote quote=»olo»]
[quote quote=»m-pmg»]
eso es una foto?
[/quote] Es un chop.
[/quote] un chop?
o está hecho con el paint?Eso ya no lo sé, yo diría que chop pero no sé. Lo importante es que no es una foto, que es un A4 cambiado con algún programa informático. *Imagen editada*
http://i29.tinypic.com/14kl2sm.jpg [i]Downsizing engines and adding forced induction is the new wave in fuel economy engineering as companies strive to maintain performance levels and the latest reports indicate Audi is leaping into the ring with both feet, lopping two cylinders from its mighty RS4 sedan and replacing them with a supercharger. Enthusiasts may lament the loss of the extra pots, but purists will relish the return to six-cylinder forced induction.The next-generation RS4 will reportedly feature a 3.0-liter supercharged V-6–the same basic unit found in the somewhat tamer S4, though it will no doubt be in higher tune in its RS application. The outgoing generation RS4 is powered by a 4.2-liter V-8 rated at 414 horsepower. Power figures for the new engine aren’t yet known, but the new supercharged V-6 is expected to be thoroughly sporty.
Adding the requisite power bump in the next-generation RS4 model would place output on par with the V-8 model, and thanks to the supercharged induction, a very wide torque band would be available from an even lower RPM–all ingredients for very strong performance.
The original Audi RS4 featured a forced-induction V-6, though it was a twin-turbo unit generating 261 horsepower from its 2.6L displacement. Efficiency ratings of forced induction technologies have advanced somewhat since the first twin-turbo RS4 was built in late 1999 and the addition of twin-turbos or any dual-charging system to the current RS4 has been dismissed as prohibitively complex and expensive for the gains over a single supercharger design.
Whether Audi will actually follow through with the return to a forced-induction six-cylinder or not remains to be seen, but with impending fuel and emissions standards tightening around the world, even the high-performance luxury carmakers will have to change to keep fleet averages in line. No word yet on a release date but in the meantime, check out our latest computer-generated rendering which gives us an early look at the aggressive lines Audi’s designers have planned for the new RS4.
Incidentally, Audi is set to launch its RS5 based on the A5 Coupe early next year. This model will likely get a 450 horsepower version of the current RS4’s 4.2-liter V-8.
[/i] [url url=http://www.motorauthority.com/blog/1034159_rendered-next-gen-audi-rs4-avant][u]MotorAuthority[/u] [/url] Será un RS5 con dos puertas más y el mismo motor, que no se coman mucho la cabeza, ni los chopistas ni nosotros, la nueva linea RS la adelantó en su dia el TT-RS (solo hay que ver las últimas espias del RS5). [img width=650 height=364]http://i53.tinypic.com/2v0oaib.jpg [url url=http://decoches.blogspot.com/]decoches.blogspot[/url] salu2
Exacto, unos accesorios nada más por lo que se ve. Por cierto.. qué indican las flechas?
[quote quote=»Kenny13″]
Exacto, unos accesorios nada más por lo que se ve.Por cierto.. qué indican las flechas?
[/quote] Una nueva parrilla. En la anterior los aros flotan, en esta descansan sobre la barra de color negro.
salu2[quote quote=»kronos»]
[/quote] Eso es un reflejo del cristal que hay entre el coche y el objetivo de la camara.
Eso es un reflejo del cristal que hay entre el coche y el objetivo de la camara.[/quote] Yo veo dos parrillas diferentes, la actual con los aros flotando y la nueva con los aros encima de la barra negra.
[img width=586 height=170]http://i54.tinypic.com/v5l2z7.jpg salu2
Si miras todo el contexto de la foto verás que esa franja blanquinosa es un reflejo que va de una punta a otra de la foto. [quote quote=»kronos»]
[/quote] y porqué tienen la misma matricula??
:pensando: Yo veo la misma parrilla con un reflejo que clarea la imagen en ese punto.
Es verdad que si te fijas hay una franja blanquecina justo por ese punto de la parrilla
