Subaru BRZ | Toyota GT 86 (2012-2020)
INICIO FOROS NOVEDADES Vehículos presentados Subaru BRZ | Toyota GT 86 (2012-2020)
Viendo 20 entradas - de la 1 a la 20 (de un total de 91)
  • Avatar de Fiorano
      Aquí encontrarás todos los hilos relacionados con la primera generación del Subaru BRZ y Toyota GT 86 (ZN6/ZC6)
      Avatar de Fiorano
        [i]The sporty coupe you see in the sketch above was revealed by an inside Subaru source to the good old folks from Autocar mag and it depicts the Japanese carmaker’s forthcoming rear-wheel drive coupe that is being co-developed with Toyota who as you may already know, holds an 8 percent stake in Subaru.
        According to the magazine’s sources, the two Japanese automakers are working on a rear-wheel drive coupe project based on the underpinnings of the Impreza. Despite the fact that the Subaru and Toyota variants of the RWD Coupe will differ in appearance, they will both be powered by Subaru’s 2.0-liter and 2.5-liter 4-cylinder Boxer engines available in naturally aspirated and turbo versions.
        Even though Subaru and Toyota’s prime objective is to create a nimble, lightweight RWD coupe, the possibility of a top-notch AWD version should not be ruled out. Sources have stated that the final design of Subaru’s version of the RWD Coupe is due to be signed off in July, with production set to start sometime in 2010.[/i]
        editado
        Via: Autocar
          Una recreación;
          [url url=http://img523.imageshack.us/my.php?image=848852419ka7.jpg][img width=150 height=115]http://img523.imageshack.us/img523/5206/848852419ka7.th.jpg[/url]
          Avatar de Moverano
            Me recuerda un poco al hyundai Coupe. Lo raro, que Subaru es casi todo 4×4 y quieren hacer en version trasera. Tienen experiencia con dicha traccion? si las han montado otras veces….
              Es un sistema en el que trabajan conjuntamente con Toyota (esta es una de las causas de la noticia que colgué hace algunos días).
              Avatar de Fiorano
                Avatar de Fiorano
                  Avatar de FELINO_29
                    Yo opino que esta información es bastante prematura, no creo que a estas alturas ni la propia Subaru sepa los datos del coche, bueno a lo mejor el proyecto está mas adelantado de lo que creo, ojalá!!  :grito:
                    Avatar de Fiorano
                      Avatar de CgD
                      CgD
                        Vaya par MÁS bajo para 220 cv. Sólo 21 cuando un 1.8 TSI de 160 cv es de 25.
                        Avatar de nautiliux
                          Yo veo un Hyundai Coupe.
                          Avatar de Jalmenaraster
                            Yo un Hyundai Genesis Coupe, que no es lo mismo…
                              Eso mismo iba a decir yo…
                              Avatar de nautiliux
                                [quote quote=»BlackSeries»]
                                Genesis o Nemesis, pero me entendiste.
                                  Pues no del todo, porque el Genesis es un modelo completamente distinto del Coupé a secas… Entonces, pensé que a tí te parecía el coupé normal, y a mí el Genesis Coupé…
                                  Avatar de Fiorano
                                    [img width=600 height=254]http://i44.photobucket.com/albums/f30/trev2/setch2.jpg
                                    autoscoop
                                      Pone Toyota y es un Lexus, pero lo que me pregunto es por que esta en un tema de Subaru, si hacen un modelo conjunto, debería de detallarse en el titulo, para que se sepa que hay info de Subaru y Toyota.
                                      Avatar de Fiorano
                                        [quote quote=»marea»]
                                        marea, el tema se ha separado para que cada modelo tenga su hilo. Se hace con los hilos que se puede y he considerado que era mejor así. La info de este hilo es del Subaru y toda la que hay en el otro es de Toyota.
                                        Repecto a la foto del Toyota / Lexus, ya está editada. Me he equivocado al subirla.
                                        Avatar de Fiorano
                                          [i]TOKYO — As if paying homage to Subaru, Toyota is co-developing a new lineup of rear-wheel-drive sporty coupes employing a revised version of the Subaru Impreza’s platform, boxer engine and transmission. Toyota’s largest contribution to the mix will be product planning and its impeccable quality control.
                                          The Toyota model, still to be named, will be sold exclusively in Japan, while the Subaru-badged model will be marketed worldwide. The mechanical package will be identical, but both Toyota and Subaru will create exterior designs to differentiate their cars from each other.
                                          The basis for this new radical project is to take Subaru’s well-known 4WD powertrain and modify it to create a new rear-wheel-drive setup. Slated to be built at Subaru’s Gunma plant in Japan, both Toyota and Subaru models will employ a revised version of the naturally aspirated boxer 2.0-liter unit generating around 220 horsepower at 6,500 rpm, mated to a six-speed manual gearbox from the current Impreza WRX STI.
                                          Surprisingly, the joint Toyota-Subaru R&D team has chosen the out-of-production, front-wheel-drive Honda Integra Type R as its benchmark, because its styling, performance parameters and dimensions mirror what the development team wants to create.
                                          Expected to ride on a 103-inch wheelbase, the 2,866-pound coupes will use a 2+2 seating configuration.
                                          Slated for a late 2011 debut, the coupes are expected to be priced starting just under $20,000.[/i]
                                          [img width=500 height=315]http://i270.photobucket.com/albums/jj111/puhpuhpuhpuhpuh/subarufr500.jpg
                                          [img width=530 height=297]http://www.7tune.com/newtune/Peter/toyota_subaru_compact_fr_sports_car/toyota_subaru_fr_sports_car2.jpg
                                          Edmunds & 7tune
                                          Avatar de Mondeo
                                            Tiene el piquito en las luces [i]a la Nissan[/i]. No creo que se llame Impreza si es RWD
